daniel_lyall
in reply to: jeph00
It really depends if you want it cut to the shape of the part, wrapping pretty much can't cut stuff like that very well at all, If you want the shape it will have to be cut from the bottom of the part then use a forum tool to finish it.
Also if you look at the toolpath sim with the stock set to transparent you can see it is cutting straight down.
If select the bottom it more than likely will not eat the part.
Using a 15-degree conical cutter.
Example attached.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
