01-11-2021
04:17 AM
- Mute
- Permalink
- Report
01-11-2021
04:17 AM
A 5-axis path will take longer to generate than a 2-axis path. So with that in mind that it needs a little more time isn't too weird. I do think the processor you have in your PC makes a huge difference here. So if you aren't running very fast hardware you'll see longer wait times. What kind of CPU do you have?
A quick way to get a rough path is to set the tolerance to 0.1mm and see if it cuts as you expect. Than make the tolerance what you want/need only when the rest is set correctly. Also generally the more you let the operation do the longer it takes, so if you use surfaces for selection, or automatic synchronization it will take longer.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Fusion
