Dear Marco,
thanks a lot!
I am unsure if this is the solution because:
- This operation will use G112 polarmode even with your manual NC disabled.
- I intend to use this for radial milling. I tried using the manual NC as per your example.
This did not work.
I never found a way to make this work and I am afraid, this is not possible.
