joelnap
613 Views, 2 Replies
3D Adaptive avoid surface/boundary
I have been working some years with Fusion mostly 2d strategies for CAM, and recently have started really getting into 3D CAM. Our machine is a simple one, 3-axis with a max working height of 200 mm(235 mm under the holder).  The project I am currently working on is however 185 mm high!. I was just able to fit a small 8 mm mill in, and managed to mill the first 185-123=62 mm down. Now I would like to go deeper into the object, by fitting a 10 mm mill, that has 80 mm length under the holder. Obviously it cannot retract over the object, as it is still 185 mm high, so it must stay down!!.  Cannot find how to make 3D Adaptive avoid the previously processed stock, it still sometimes plans right through it(or tries to go over it) Have made a new setup using the stock of the previous setup(the 8mm mill), and tried all sorts of things: machining boundary, fixture definitions, etc.
Have partitioned the machining boundary in 4 quadrants to see if that woudl help.
This was a lucky shot I guess, here it worked:
This is mostly what I get, right throught the previous result, the tool path is good, intermediate move seem to ignore the boundaries..:
Anybody any ideas?
Tags (1)
Labels (1)
