- Mute
- Permalink
- Report
Have a Spiral tool path that is working fine on one part in the same file and not at all on the same part just mirrored. Attached is the f3d. If anyone has suggestions id love to hear them. Been fighting Fusion all day it seems.
Thanks Everyone!
- Mute
- Permalink
- Report
If you select both, and do Compare and Edit, you will see there are plenty of settings different between the two.
If I make them all the same except for the clockwise direction it generates without any issues.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
- Mute
- Permalink
- Report
Thank You Laurens! That did the trick, a lot of what had been changed was me messing with settings trying to get something to generate, it started as a copied tool path originally and went back through and selected the appropriate new geometry, but I obviously missed something prtty **** important in there somewhere. Appreciate your help!
Fusion
