FrodoLoggins
840 Views, 4 Replies
Ramp angles are different
Specified ramp angle: 45 degrees.
Some ramps are 45 degrees, some are more like 5 degrees.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
seth.madore
in reply to: FrodoLoggins
This has always been a tricky one to get to perform proper. I find that by defining a start point on a long edge, I can get it to behave properly:
The dev I'd like to talk to about this is out (different time zone) so I'll raise this with them tomorrow
Seth Madore
DarthBane55
or change the maximum ramp step down to something really big like 10".
AhhhH!!! Thanks @DarthBane55 !!! I only had to set maximum ramp step down to 1" instead of 0.25" and that made it work perfectly.
The ramp will limit itself to your max stepdown, per complete revolution and 'ignore' the angle. It's always been like this.
Please click "Accept Solution" if what I wrote solved your issue!
