12-04-2020
04:29 PM
- Mute
- Permalink
- Report
12-04-2020
04:29 PM
@conjured2018 wrote:
Men, solution worked perfectly. Thank you.
Daniel, if stock size, Z in set up reads .84, not .75 can selecting model top model bottom be correct? I have been using for bottom, origin -,75. in operation model bottom reads .76. I just offset to correct depth?
Yes, you can do that and for some reason, it is working today with just fixing the setup. It is just using model top, and model bottom, is faster as you have to edit the bottom height offset with the way you do it now, and yes if you do not want it to cut all the way through you have to use an offset anyway it is done.
With Fusion you can do it anyway you want to a point.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
