433 Views, 4 Replies
2d pockets connecting, with different depth
hello
I'm pretty new to cad / cam. And i have trouble creating a 2d pocket with a finishing pass. The problem is that I do not manage to create one or more 2d pockets that manage to mill the different depths. to complicate matters further I want ruffing to be climb milling and finishing I want convetional. to get a nice surface on foam and at the same time avoid long threads getting stuck in the 3,175mm endmill. It's the two left rows I do not succeed with, where the spanners are standing on it's side.
Do you guys have a guide/tips for how to make this possible in 2d, or do i have to make it 3d?
Labels (1)
daniel_lyall
I find it a lot easier to do the finish as a second op all you have to do is duplicate the roughing toolpath and change the settings you want to be different or do a derived op if a different toolpath is needed, these are in the right-click menu on a toolpath.
Cutting different height levels can be hit and miss some time with 2D ops, I just do a 3D op as this is model aware, and 2D ops have to be made to go where you want them to cut as they are not model aware.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
in reply to: daniel_lyall
Thanks for you comments.
i have tried a 3d pocket, but i takes fore ever. Is there a way to not machine the whole part at every depth level of the model? as you can se in the model i attached there is a differnt depth on every tool slot. Hope you understand what i mean.
daniel_lyall
Do you want to cut to full depth on all of the pockets in one go and then do a finishing pass?
Daniel Lyall
The Big Boss
Mach3 User
the endmill i am using only have 20mm flute length so on some places i have to do it in two cuts. but yes one go and then finishing, but not the bottom only the sides. The bottom does not look good after a small finish, due to soft foam material.
