crullier
in reply to: seth.madore
@seth.madore  I know that this is a bit old of a thread, but currently, in Nov 2020, is the 2d profile with a negative stock to leave (radial) the way to program a slitting saw?.
I am also curious as to what is the best way to program the tool into fusion. I am using a slot mill definition for this:
I have not used one of these cutters before, I am guessing that you don't just cut full radial all at once do you? (on 6061 and even plastics)
I am also curious to know what would be the best way to make a slit that is 3 times the thickness of my blade, so I just copy the tool path 3 times and play with the axial offsets? Thank you
