mattdlr89
633 Views, 4 Replies
3D Contour Machining Around the boundary
I'm getting a problem (which I've seen before) where the 3D Contour is machining the air around the tool boundary (see pictures). It doesn't matter if I select, Bounding Box, Silhouette or selection.
As writing this I realise that it goes away if I select "Rest Machining". Is this intended behaviour?
Tried to attach a file but it is taking an age to export it...
in reply to: mattdlr89
If you don't need fixture attached to model for purpose of detecting crash, just remove it and save file in f3d format then upload.
I find f3Z files awfully annoying and in many cases people stuff their file with junk just for illustration purpose which makes it a nuisance to share.
Laurens-3DTechDraw
I'm pretty sure the answer is you have unchecked the contact only box on the geometry tab.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Laurens Wijnschenk
3DTechDraw
René for Legend.
That seems to fix it! Thanks, it has frustrated me  a few times in the past so good to know how to cure this.
