- Mute
- Permalink
- Report
OK, I`m game for a crack at this, I have done a small example just turning a 50mm bar down to 40mm using a Profile Rough and two separate Profile Finish Passes and it seems to work fine and the code looks right to me, I think that you may not be reducing you stepovers in the first finish in order to actually leave some stock for the second finish pass, too much to type out for my old fingers so I have attached the Fusion f3d file, the nc file and the HAAS PP file that I used, run the simulation and click on the "Info" tab and you will see the cut depths for each pass, pause it and then do single block moves, a lot easier to see what is happening.
The roughing goes to X41, the first Finish goes to X40.2 and the second finish goes to X40 which is exactly how the operations are set, ignore feeds/speeds etc, this just to show it working
Hopefully you can make sense of the above, I tend to ramble a bit !! (Just playing the AGE Card)
Stay Safe
Regards
Rob
Fusion
