engineguy
in reply to: engineguy
@seth.madore
Just an update, I was able to replicate the issue by creating a sketch and deliberately placing it at a very small angle using the Rotate and selecting one edge as the rotational axis, then extruding the hole from the sketch and found that the Hole Face could not be used but Diameter and Point works so from that it does sound like this is being caused by "dodgy" sketches.
Just for fun I tried to extrude a surface using the "press pull" and got a really weird result :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
Moral of the story, create holes in the solid and not from sketches would seem to be the safest way :slightly_smiling_face:
Stay Safe
Regards
Rob
