engineguy
in reply to: seth.madore
@seth.madore
It must have something to do with the plane that is being used to create the hole, little experiment, I created another hole in the block and as before it works fine, now, selecting "same diameter" the bad hole is now selected as well so that would in effect be using the "diameter range" which we already know works OK.
How can the original hole be created at an angle from either the top or bottom faces is a mystery, as I am not able to replicate the issue here on any random existing files I have or any new ones I would have to suspect an issue with the OPs Fusion setup, another thing that happens is if I use the Tool Orientation to select the Z direction using the Hole Face then again it works OK, possibly a sketch is being used to extrude the hole, I`ve tried that but still am not able to replicate the issue, I always use the "Hole" in solid method and I have never come across this !!
It is like there is a "Draft" angle on that face somehow ???
Stay Safe
Regards
Rob
