mashcomDWK67
in reply to: engineguy
Hi @stanskimaciej
Thank you very much for the postprocessor. It seems it will work. Is it set anywhere in Fusion 360 that the X-axis and the Z-axis must be changed? I'll remove the offset of the tool as you mentioned.
Hi @engineguy
Thank you very much. Why do I have to use G54, G55 and G56? What happened was that the controller does not support the offset of the tool but the X-axis has been displaced. I only set G55 0,0,0 and G56 0,-350,0 in the controller, so the vertices of both of the tools start milling from the original point. The situation is the same with the T1 spindle where there are different values for Y, X and Z. The controller supports 10 additional coordinate systems.
