- Mute
- Permalink
- Report
The X and Z positioning are generated by the Post Processor that I used, which is the same one as @stanskimaciej has attached to his reply, just download that one and copy and paste it into your Personal Post Library, see image.
Once you have that open scroll down to the "Open Folder", click on that and then paste the new PP into that folder, close that Posting area by clicking "Cancel", then re-open and you will be able to select that PP from the drop down list on the left where it is showing the PP I used, the 5AXISMAKER / 5axismaker - Copy4
I am puzzled, you said that you need a G55 to start your Left T2 spindle and a G56 to start your Right T2 spindle so you need to have multiple WCS for your control, the warning in your image is simply saying that you need to be using a PP that is enabled to handle multiple WCS
Hope you are nearer now ![]()
Stay Safe
Regards
Rob
Fusion
