- Mute
- Permalink
- Report
Right, it is the normal M3 S**** to start the spindle, the WCS setting G54/G55/G56 etc will I expect start the appropriate spindle so in the attached G code sample I have set it to G55 so the T2 spindle on the Left looking at your photo should start, see image below for where you set the G54/G55 etc, setting it to 1 is G54, 2 is G55, 3 is G56 and so on for as many as your control is enabled to handle.
Have a good look at the attached G code file, it moves in the Z axis down to level with your slot, and then moves along the Y and Z axis for direction of cut, it is a 2D Pocket and as the tool is only 12mm dia and the slots are 18mm and 16mm then the Machine Z axis will move up and down a small amount, the X axis is acting as a Z axis and moving deeper into the edge of the door which to me is all correct ![]()
Hopefully this will get you closer !!
Anyway, see if your control will accept the code and gently try it out well above your machine bed
Usual caveat applies, use at your own risk
Stay Safe
Regards
Rob
Fusion
