engineguy
in reply to: mashcomDWK67
@mashcomDWK67
Could do with some more information, never having used a CNC with that configuration I have to assume things :slightly_smiling_face:
1) When you switch over to your T2 spindle does your CNC control do a "swap axis" so that looking at your photo the Z axis now moves Left and Right instead of X and what was the Z axis with your T1 spindle becomes the X axis and the Y axis remains moving away from and towards you ???
If that is the case then we can possibly look at producing G code as if it is a 90 degree index move on a 4 axis setup.
Info please :slightly_smiling_face: :slightly_smiling_face:
Stay Safe
Regards
Rob
