seth.madore
There's a LOT of stuff packed into your last question. I'll address most of them here, as I can.
1) Defaults for each tool; for some toolpath settings, this is not possible. You can set stepover/down at the tool level via Presets (using the new Tool Library) Is T2 ALWAYS roughing, same size tool? T3 is ALWAYS finishing, same size tool as always?
If so, create Templates. Program a generic part, setting all your toolpaths to your preferences. Select all your toolpaths, right click and "Store as Template"
Stock Box and Model Orientation are defaults. Those too can be changed. Change them to your preference and right click in a text box (program comment, for example) and select "Make All Default"
Unsure what you mean about Chamfer and compensation. Can you share an example?
Seth Madore
