in reply to: seth.madore
Okay that is something, but still I see no way to make defaults for each individual tool.
For example T2 is rough mill, it needs to have axial and radial material left after it mills part.
T3 is for finishing, flat end mill, it doesnt need axial and radial material left after it mills part.
T4 is chamfer mill, it doesnt need compensation so it needs to be "In computer" instead of "in control".
All of those things aren't saved for each tool using your method.
I still need to change every tool in new part after everything was saved in last part. No defaults for each tool.
Also, I want universal tool library, I don't want my changes keep effect in next part beacuse what I change in my tool library for last part, will stay saved for next part.
How to have universal tool library so every tool saved there stays the same for each and every new part I am creating?
Why is "Stock box point" default while choosing WCS and not "Model box point"? Why is "model orientation" default and not "Choose Z plane and X axis"?
Final question, why if I use "in control" for chamfer mill and leave all settings the same as in "in computer" my chamfer mill will creata alot bigger chamfer than necessary, like it alters path for that tool with changing from "in computer" to "in control"?
