seth.madore
I'm going to show you something that's going to totally blow your mind: Setting defaults.
Go into a toolpath.
Change everything to how you want it to be, reflective of your preferences and settings.
Click on any text box and select the "Make All Default" button:
As for the Heights, here is my preferences, which will get you pretty close to what you are looking for:
If at any point you decide one of the settings is not ideal, right click on the toolpath and select "Compare and Edit". Once in that new dialog, you can right click on almost any field and change the default behavior.
Seth Madore
