mashcomDWK67
405 Views, 1 Reply
Is it possible to set offset to the X-axis?
I have 3 axis CNC router with two spindles - one vertical and one horizontal. Both of the spindles have been mounted on the Z-axis. The problem is that I can set an origin point only in T1 but when I use T2 I have to define some offset to the X-axis in order to use the second spindle. The Y and Z-axes are the same for both of the spindles. Is it possible to set offset to the X-axis in Fusion 360, thus solving the problem? I have attached a photo to see the position of the spindles. The controller of the CNC router is Richauto A15.
Labels (1)
