11-01-2020
01:19 AM
- Mute
- Permalink
- Report
11-01-2020
01:19 AM
Is it possible to set offset to the X-axis?
I have 3 axis CNC router with two spindles - one vertical and one horizontal. Both of the spindles have been mounted on the Z-axis. The problem is that I can set an origin point only in T1 but when I use T2 I have to define some offset to the X-axis in order to use the second spindle. The Y and Z-axes are the same for both of the spindles. Is it possible to set offset to the X-axis in Fusion 360, thus solving the problem? I have attached a photo to see the position of the spindles. The controller of the CNC router is Richauto A15.
11-02-2020
04:31 AM
- Mute
- Permalink
- Report
11-02-2020
04:31 AM
Yes, but it will require some post edits. This is outside the realm of what's common to assist with, so I'm going to point you in the direction of our post edit resellers
Seth Madore
Fusion
