- Mute
- Permalink
- Report
From what I have been able to test a "Manufacturing Model" only exists in the Manufacture environment and can not be modified/updated from the Design environment, only the original model created in the design environment can be modified/updated in the design environment.
Again, from what I see the Manufacture Models are really only for things like Fixtures/clamps etc which means they can be added/moved/modified as required without affecting the main original model, they seem to be best used to add items that would need to be cleared/avoided by the main toolpaths, I will try to have another go at a test file but if in the meantime you have a Fusion file that you would like someone to have a look at then please upload it by going to File>Export>Select f3d format>save to a location on your computer>then attach the file to your next reply ![]()
Stay Safe
Regards
Rob
Fusion
