- Mute
- Permalink
- Report
So far, I have used fusion about a dozen times to create toolpaths for my cnc router. All of those toolpaths were for items with vertical sides, so just straight forward profile cuts.
This file (Honda logo) I want to cut from 16mm craftwood and is more complicated than the others and I'm at a loss to know what type of toolpath to use and how to set it up.
I have a feeling it's going to be a steep learning curve.
Can I get some help with it please ?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Here's a few resources from the help documentation to help your choice of toolpath selection:
2D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID32D2B912-191D-41E7-81DA-07F6EC4B91A2
3D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID9F9002B3-53E3-4859-A0DE-499D8529DA8C
Once you've decided on a toolpath, you can view its detailed parameters here:
2D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID20E579E7-B808-47D1-BFB2-14056A2B1CFE
3D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID4F934FCC-2283-4429-8C36-F3D11CD917F4
Hope these links help with your learning curve. Don't hesitate to reach out if there's any information you'd like to see more of.
Shabbir Abdulhussein
Content Designer
- Mute
- Permalink
- Report
So, do you mean use 2d pocket for the internal cut outs, 2d contour for the external circumference and 3d* parallel for the sloping shapes ?
- Mute
- Permalink
- Report
i just grabbed a tool and did the simple toolpaths. you will have to change tools and speeds and feeds accordingly.
- Mute
- Permalink
- Report
Ah ok thanks for that.
I changed things a bit and I think it might work ok with my model.
- Mute
- Permalink
- Report
Fusion
