engineguy
in reply to: stanskimaciej
@stanskimaciej
Have you tried a simple 2D pocket and setting the PP as if it has 4th axis running in the "Y" ??
See image below and attached file, also G code that runs with no errors in Mach3 here, or try generating the code using your own PP :slightly_smiling_face:
Might help point in the direction you want :slightly_smiling_face:
Stay Safe
Regards
Rob
