- Mute
- Permalink
- Report
You have 2 setups, one for under the part, one for the top. I posted a few different ways:
-posting the 1st setup, the tools output in correct order, only once per tool.
-you have multiple WCS offsets turned on, so it outputs the code for 2 parts, without calling the same tool twice, which is how you set it, this seems correct.
-Posting all setups at the same time, then yes the tool come back for the 2nd setup. It will not jump over tools to avoid outputting a tools twice. For example, in the setup 1, the tool order is T1-3-2-4-8-5-6-7.
2nd setup: T8-7-1-2-6
So it will not do 1st setup T1 then 2nd setup T1, because in the 2nd setup T8 and T7 need to be done before T1, if you see what I mean. If in the 2nd setup T1 was the 1st tool to run, then yes, it would output T1 only once and run it in both setups in a row (I tried it and it works as expected).
Fusion
