- Mute
- Permalink
- Report
Now, how weird is this, it is in fact changing the order but because there are somehow duplicate toolpaths when you move a toolpath in the browser up or down it seems to be the one lower down the order in the code that does move.
Why there are duplicate toolpaths I have no idea, they don`t appear in the browser, not that I can see anyway, needs someone with a lot more knowhow than I have to answer that one
What I have done in the meantime to maybe help you out is to re-create your toolpaths on a new "clean" model and everything works the way I think it should, I have only done the one side as the second side seemed OK and I will leave you to re-do that side ![]()
Hope this is of some help to you, if you know why you have all the duplicate toolpaths and are able to get rid of them at your end then that would probably fix your problem
Modified file attached.
Regards
Rob
Fusion
