Mattxer
From what I've found online, you should run 15K rpm, use like a 2 flute HSS (something very sharp) and you want to be pretty fast with your feeds. Is it like solid foam or like the bead type? (XPS/EPS)
I found this chart online:
I hope this helps!
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
