700 Views, 9 Replies
Polystyrene Machining
Hi everyone,
I was hoping if someone could help me in selecting good tools for machining polysyrene foam (expanded) in Fusion and also how can i minimise the machining time. And how can i justify those slected parameters as from the manufactrure module i also have to machine it in real. So i am open to ideas. As of now am going crazy about the rpm and feed that i could use because higher spindle speed or feed rate might burn the foam.
thanks in advance....
Cheers!!!!!
