twood213
in reply to: krummeck
I use trace tool path for engraving.You can do multiple cuts to a depth you want by using a axial offset.You are able to set the number of cuts that you want take to get to required depth.
I’ve recently had success in engraving hardened steel using a dbit.The  cuts where only 0.02mm to a total depth of 0.16mm .I was very surprised it worked as I didn’t think the cutter would last
