rom_gerrun
339 Views, 2 Replies
Syntax error post processor mac
Hi guys,
So I'm working on a mac and trying to figure out a Heidenhain post pro for a 5axis dmu50
Since I'm working on a mac I had to make a change to the PP to actually work.
Here is the procedure:
https://knowledge.autodesk.com/support/autodesk-hsm/troubleshooting/caas/sfdcarticles/sfdcarticles/E...
But I still have a syntax error and don't understand it
Iv'e attached the pp and also the error I have when post the code.
Thanks for the help
randyT9V9C
in reply to: rom_gerrun
You are missing commas at the end of lines 60 and 85. Syntax is sometimes hard to see but it will get you everytime.
60   preferTilt: "-1", // -1: negative, 0:dont care, 1: positive TAG: Mac
85   preferTilt: {title:"Prefer tilt", description:"Specifies which tilt direction is preferred.", type:"enum", values:[{id:"-1", title:"Negative"}, {id:"0", title:"Either"}, {id:"1", title:"Positive"}]     }, // TAG: Mac
I've attached the corrected post processor.
rom_gerrun
in reply to: randyT9V9C
Hey perfect it worked.
Tank you for the help
