pete.oxenham
in reply to: krummeck
There's a lot to get into, but basically the "engrave" operation is not what you want to be using for the toolpath you're trying to create. Try 2D contour, or chamfer.
As far as the engravings go, my personal preference (which is wrong) is to use the "Trace" toolpath and then do a G52 shift for whatever depth is needed. Alternatively you can use 2D contour with compensation set to "Off" and lead in/out disabled, then set the bottom height as "Selected contours" minus whatever depth you want..
Pete Oxenham
Chatter.dev
