It is cutting backward this is the first time I have seen this happening.
It is the toolpath selection doing it.
Traces does not have a stepover just stepdown so it is a one-hit-wonder.
Now to get it to do 2 step-downs in the same toolpath you select the outside side edges first do the edit toolpath dialog then select the rest of the toolpath hit ok, now select the inside side edge do the edit toolpath dialog select the rest of the toolpath hit ok this should give you 2 depths that are the right way around.
Example attached.
If you have it as a single toolpath you get this
if you select like I said above you get this.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
