08-05-2020
09:28 AM
- Mute
- Permalink
- Report
08-05-2020
09:28 AM
I first opened your project and to be honest WOW that's a ton of drilling ops. Have you considered using "Patterns" to reduce the programming work? you can program all the ops for one of your pieces and use a Pattern to apply it to all of them (or at least the ones with equal spacing). Or you could just select multiple holes in one drill op, it would save you a ton of time and if you need to make changes it applies to all of them. Also wondering why you have a top and bottom op for every hole, why not just do both at the same time with one operation? I'm kinda confused about your deburr question though could you elaborate a bit more?
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Fusion
