jeff.pek
in reply to: BenzyMH
I'm not quite following what the issue is. You said you moved them directly into the local cache folder. I assume you did this while Fusion was running. And you say that they got uploaded to your Assets project tools folder. Then you're showing your side data panel, and they're not there. The side panel should be showing exactly the same thing as the browser view of that project.
Do you have different hubs?
Jeff
