02-11-2016
03:13 AM
- Mute
- Permalink
- Report
02-11-2016
03:13 AM
I have not had great luck with having the G187 done automatically in the post. It uses some logic to determine if you are leaving stock and if it is greater than your operation tolerance.
Part of the problem is that it sets E to what ever you have set in you tolerance for the operation. So it you have your tolerance set to .001" and are leaving stock you would get G187 P2 E.001 The default setting from haas is G187 P2 E.025 IMO changing E to .001 slows it down not speed it up from default.
I changed my post to output G187 P1 E.05 when I am leaving stock.
You can also set G187 without changing E value if you want to just leave it at the default that is set in the settings.
Fusion
