seth.madore
in reply to: crullier
If you use the new tool library, there are some settings you can adjust at the tool level that will propagate across any toolpath that is using that tool. Examples include:
1) Feedrate
2) Stepdown
3) Stepover
Note; For this to work, you need to apply the changes to a Preset and select that same preset in the toolpath. So, is it retroactive? No. But, like anything else in the program, start building your process to account for this and it becomes a non-issue in the long run.
Seth Madore
