07-06-2020
04:39 PM
- Mute
- Permalink
- Report
07-06-2020
04:39 PM
Using the same tool path in multiple patters
Hello guys,
I have a part of perforated faces. All the perforations are the same but are patterned differently across the part.
I found my self having to diplicate the base toolpath several times and what is worse, if I needed to make an adjustment, I had to make the same adjustment in several places. Is there a way to automate this so a change such as chiploap for instance can be made in once place?
I am sure you can use custom parameters, but that takes time to setup.
Thank you
Fusion
