Collin_Korver
233 Views, 2 Replies
New tool library not updating subsequent operations
there is a bug where if I modify the cutting parameters for a tool in the new tool library it does not update the cutting parameters operations where that tool is being used.
@Collin_Korver  Would you be able to add a screencast please? Is this when you define a cutting preset and expect the changes within the preset to reflect in the operation? Some users have reported similar issues but they missed the "Preset" dropdown on the operation feed and speed panel. It must be set to the preset you modified. If this is not the case then you are right it is a bug which we will treat as high priority.
Chris
Christopher Cooper
Technical Consultant
I did have it on custom, so that was the issue. I just had it where I broke a tool because the preset was custom, I went to the tool library and updated the default but none of the tools were updated. There is no indicator to which operations are to what preset. I also cant find preset on 'edit all'
In the tool Library, one can see what operations are being used by that tool. It would be a good safety feature and streamline adjustments to display the operation and the preset the tool is running to, maybe even be able to change it from the library.
