- Mute
- Permalink
- Report
@ege.gener wrote:Thank you for your comments. I did not realize the formed tool requirement of lathe operation, that's why I thought that it will be easier on lathe. 4 axis milling toolpath will run for 7-8 hours if everything goes smoothly. Is this a reasonable duration or I just use very conservative feed/speed values?
Well, to clarify, running rotary tool path on lathe's C axis is same as running it on 4th axis mill with mill having huge advantage in RPM, spindle rigidity and number of tools you have at your disposal compared to lathe.
I mentioned form tool as an option to speed up the process but you would have other potential issues like having to make the tool, wait for it, pay for it, .... and if it brakes or doesn't work as expected you have more problems.
With form tool, you can also do it on mill if you think gain in cycle time is worth the risk.
As for 7-8 hours cycle time, plus all the other work, I have no idea what material you are cutting, but if you charge enough money to run it for 8 hours, it's not a problem, grab some chips, pull up a chair and grow a bird while it runs.
Fusion
