in reply to: ege.gener
Why do you thing this can be done on lathe faster then on mill? These are not concentric grooves, if they were you could use grooving on lathe,.... but they are not.
Using C axis on lathe to cut spiral grooves is same as using 4th axis on mill with big disadvantages, lathe rotary tools are far less rigid and have very limited RPM's compared to mill, you still have to use same tools and your cycle time will increase significantly because of it.
