kretallick144
Wow, you have been busy!
I have it oriented that way as i will use a fixture to hold several parts at a time.
My plan was, raw stock, face,  drill and machine finish the bores. Each part individually.
Then mounted onto fixture held by internal expanding arbors inside the bores.
machine outside profile, top, etc.  Flip and repeat.
I see you have a blend path,  Im unable to open it on my license?. No stress i was planning on using a  corner radius tool to machine those features.
Your work will be of immense help to learn the strategies for the path setup!
