in reply to: kretallick144
To contour the outside you need to create conditions for what you intend to do, I projected all surfaces onto plane, saved resulting sketch as dxf file, undo sketch then import that dxf file into new sketch, trim geometry I don't need to come up with outline of model then use that as geometry in operation.
You can also use your first sketch but you need to hold down ALT key and select segments of sketch to outline the cut.
