in reply to: lee_sanders
Sure thing. Let me also add more explanation.
In Setup 4, I have a pretty standard 2.5 parallel pass (except the rapid plunge. I can get away with that using this tool.) However, the problem arises between where fusion things the outer edge of the cutter should be and where is it in reality when moving from left to right in the figure. The simulation and the real tool are the same if looking in the direction of the red arrow.
I do understand that the shaft would collide with the stock at point (a), but I'm just using this part for a demonstration.
