engineguy
@Anonymous
There is probably a way to do it in the "Boring" strategy but like you I can`t find it (Bug??), so the best I was able to come up with is a not very pretty workaround of using the 3D Contour strategy, it seems to work but the file I have attached will need some serious cleaning up regarding stepovers/downs.leadins/outs etc, etc, however it may give you a starting point to get going :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
As you can see it is pretty much "Transition" moves so feedrates will need careful setting but it might get the job done unless someone else has a better way, I am sure there will be :slightly_smiling_face: :slightly_smiling_face:
Regards
Rob
