530 Views, 4 Replies
The problem with boring conical holes!
Hello everyone, colleagues.
I have a problem with boring cone holes.
I have already tried changing all the settings for operation "Bore".
For a cone with a positive angle, the trajectory is correct.
For a cone with a negative angle, the trajectory is erroneous.
Please help, who knows how to resolve the issue.
Sincerely, Alexander.
P.S. The project file in the attachment.
engineguy
@Anonymous
There is probably a way to do it in the "Boring" strategy but like you I can`t find it (Bug??), so the best I was able to come up with is a not very pretty workaround of using the 3D Contour strategy, it seems to work but the file I have attached will need some serious cleaning up regarding stepovers/downs.leadins/outs etc, etc, however it may give you a starting point to get going :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
As you can see it is pretty much "Transition" moves so feedrates will need careful setting but it might get the job done unless someone else has a better way, I am sure there will be :slightly_smiling_face: :slightly_smiling_face:
Regards
Rob
seth.madore
2D Bore is not intended to work in that manner. I'd suggest using Ramp instead:
Seth Madore
engineguy
in reply to: seth.madore
@seth.madore
Seth, I did try Ramp but plumped for the Contour :slightly_smiling_face: :slightly_smiling_face:
Regards
Rob
Thank you very much everyone!
I will try it.
