I have old test file that was free of any warning flags and now has that same warning flag you are mentioning.
This was setup for mill-turn, easily convert to 4th axis mill, note that to get spline walls done, I have taper mill because tool orientation and wrap cannot be used together and because of helix wrap must be used.
If splines were strait, you could use tool orientation referenced to vertical edge of spline with standard flat end mill to remove taper after wrap operation.
File still posts fine for mill-turn so that warning is nothing to be concerned with.
Also, if you search 4th axis related work, about dozen threads come up with more samples.
