alan
391 Views, 2 Replies
Contour With G68 Rotation Problem
When running the Contour part of this program the plane changes from G19 to G17 and back to G19 which is not allowed with G68 rotation enabled.  The machine is a Haas PreNGC.  The contour is actually a chamfer.  Can someone help Please?
I have attached a file of the part.
Thank You Alan
engineguy
in reply to: alan
@alan
The G18 (I don`t see any G19) is being generated because you have a Vertical Radius set in both your Lead-in and Lead-out, remove the Vertical Radius by setting it to 0 and the G18 will disappear.
Stay Safe !!
Regards
Rob
alan
in reply to: engineguy
Thank you!  The code looks good.  I will try the program tomorrow and accept solution if it works.  Good spot on the vertical lead in.  I learn something new often here. :slightly_smiling_face:
