- Mute
- Permalink
- Report
I'm using the Mazak QT250MSY post from the library. I have a part that is 6" diameter and has a slot through the face. See attached picture. The machine will only go 3/4" past center in X. I'm using an adaptive clearing path. When I output the code it goes completely across the part just as it shows in the picture. How can I get it to obey the travel limits? I think it should be rotating C 180 degrees so that it can come out on the same path it entered the slot.
I looked through the post and xAxisMinimum is set to 0mm. I also found the function doesToolpathFitInXYRange, so I think it has this ability, but I'm not specifying something correctly. Thanks!
- Mute
- Permalink
- Report
I made a model with slot across middle, downloaded the post and produced code, I don't run Mazaks but I saw G12.1 and G13.1 in code that seems as good as one I would run on my machine,........... polar mode.
Tool cuts to the model center point, then C axis rotates 180 degrees and tool cuts back to top of the model.
Fusion
