- Mute
- Permalink
- Report
@Anonymous If you go through the link I posted it will answer your questions.
With your model using the sketch as the toolpath is something you do not need to do you use features on the part, if you look at the example I have selected the bottom edge of the pockets for the toolpath basically if it is a pocket you select the pocket toolpath ever 2D or 3D.
The engrave toolpath you can use a sketch or the part this toolpath is fine just the truck door will not be done very well because the sketch is above the part in that area, one thing you can do is lift the bottom hight up a little bit so it does not cut too deep or use the traces toolpath.
To cut the part out of the material you use the 2D contour toolpath and you select the bottom edge.
Example attached ask any question you have.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
